housemania
Apr 16, 2024Follower
RAX20 bricked?
Just got a RAX20 locally, it managed to go through the initial setup process via Android. It updated its self with the latest firmware and it looked liked it was working properly. It managed to score ...
Apr 16, 2024Guru - Experienced User
If a normal factory reset or a 30-30-30 reset doesn't bring the unit back to normal operation, return it to where you got it.
