Coopers22
Aug 01, 2021Aspirant
RAX20 can't see devices on Nighthawk app
Hi - AX1800 WIFI 6 model - this discussion cannot find the model number for some reason.... so have had to select random... looking for some help. The Nighthawk app was working well - something updat...
Coopers22
Aug 02, 2021Aspirant
Thankyou. I did as follows...
1. Uninstalled and reinstalled Nighthawk App.
2. Turned router and fibre off.... waited.... restarted.
When I first started app... devices showed.... briefly.... then disappeared....
I then thought it it might have something to do with a new feature offering, armour. So clicked trial... the armour can see the devices as it is working its way through all those connected... bu i can see them in the devices folder. This app has been very handy to pause my teenagers connection periodically as needed!!
Do you thinka factory reset is still required considering the above? Many thanks.
Aug 02, 2021Guru - Experienced User
You could try that.
You could also try managing it through the browser and not through the app.
