microsvc2
Jan 26, 2022Tutor
RAX20 connecting to internal server
I have a web server with an ssl certificate located inside my network. From outside the network, I can connect to it with the HTTPS:// url. From inside the network, I cannot connect to it at all (h...
Jan 26, 2022Guru - Experienced User
Might set up a specific port foward configuration to this web server if your trying to access it from the WAN side.
- microsvc2Jan 26, 2022Tutor
It connects thru the router from outside the network (i.e. at my work office) but I cannot connect to it from inside my network. When I put the url in the browser, I get a login prompt. If I click sign in, it displays the router's home page.
