mikejlewis
Feb 25, 2023Aspirant
RAX20 Devices on Network can't communicate.
Hi Everyone, I have a weird issue with my RAX20. My home network seems to have some sort of AP isolation set. I can't ping other devices or Remote connect from one machine to another. When I b...
Feb 25, 2023Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware is on the router?
3. Do you have your home network set as private on the windows pc's?
4. Is there a difference from wired devices to wireless?
mikejlewis
1. what modem/gateway is the router connected to? Modem is a hiltronics, this shouldn't be a factor because if I disconnect it the problem persists.
2. what firmware is on the router? V1.0.11.112_2.0.77
3. Do you have your home network set as private on the windows pc's? No I don't and they work when I bring them to work.
4. Is there a difference from wired devices to wireless? Yes! I can ping hardwired devices from wireless devices.
- plemansFeb 25, 2023Guru - Experienced User
mikejlewis wrote:
1. what modem/gateway is the router connected to? Modem is a hiltronics, this shouldn't be a factor because if I disconnect it the problem persists.----It does matter as double nats can cause multitudes of issues.
2. what firmware is on the router? V1.0.11.112_2.0.77---good. Its current. Ever tried any factory reset to see if it works with the default settings?
3. Do you have your home network set as private on the windows pc's? No I don't and they work when I bring them to work.---they should be set on private for windows pc's on a home network
4. Is there a difference from wired devices to wireless? Yes! I can ping hardwired devices from wireless devices.---If you can ping them, the router is going its job. Its something in how you're implementing RDP or your settings
- mikejlewisFeb 25, 2023Aspirant
Thanks I will check this, however like I mentioned if the modem is disconnected from the network I still face the same issue.
This will be my next step
Sorry yes I do have it set as private. Even when the firewall is turned off though I can't ping machines.
4. Is there a difference from wired devices to wireless? Yes! I can ping hardwired devices from wireless devices.---If you can ping them, the router is going its job. Its something in how you're implementing RDP or your settings.
Strangely though RDP works on the machines anywhere else.
It's very strange that any devices on the wireless network can't ping one another, however, I can ping the router and wired devices.
- KitsapFeb 25, 2023Master
Are any of your wireless devices on a guest network?
If yes, is your guest network configured to allow guests to see each other and have access to the local network?
