microsvc2
May 28, 2024Tutor
RAX20 dropping some connections
Have a nighthawk RAX20, it's been great. Within the past week, a few times I've lost WiFi connection to my doorbell cam, tempest weather station and myQ garage door opener. Power cycling the router f...
microsvc2
May 29, 2024Tutor
Hi. I'm using 2.4 for these items on channel 11. I'm in a single family house on .75 acres. Neighbors aren't that close.
Kitsap
May 29, 2024Master
microsvc2 wrote:Hi. I'm using 2.4 for these items on channel 11. I'm in a single family house on .75 acres. Neighbors aren't that close.
If your router has the option to configure a 20 MHz wide channel on the 2.4 GHz band, stick with that. It will do everything you need for bandwidth on IoT devices. No need for the 40 MHz wide channel. Disable the 20/40 MHz co-existence option. Re-boot the router.
