microsvc2
May 29, 2024Tutor
RAX20 dropping some connections
Have a nighthawk RAX20, it's been great. Within the past week, a few times I've lost WiFi connection to my doorbell cam, tempest weather station and myQ garage door opener. Power cycling the router f...
michaelkenward
Jun 01, 2024Guru - Experienced User
microsvc2 wrote:
A few months ago, I installed a wavlink mini wifi router (wired Ethernet to it) in my garage for my video garage door opener.
How is that wavlink router configured? To avoid all the usual "double NAT" hassles, wireless Access Point (AP) mode would be best,
What is Double NAT? | Answer | NETGEAR Support
But then you get this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
If the idea is simply to make the wifi go further, that should be no problem.
microsvc2
Jun 01, 2024Tutor
The wavlink is set to access point. There's three choices. AP, repeater and router.
- michaelkenwardJun 01, 2024Guru - Experienced User
It is wired to the router so AP is the best choice.
Just wanted to rule out other c0omplications.
- microsvc2Jun 01, 2024Tutor
No idea how to resolve this.
- KitsapJun 01, 2024Master
Your original post indicated loss of Wi-Fi signal to three IoT devices.
Later on you indicated a second source of Wi-Fi from a WavLink access point. This source is in addition to the Wi-Fi from your RAX20.
Are your three IoT devices connecting to the same Wi-Fi source or are they split up? How are they split up?
What are the Wi-Fi channel number and channel width settings on your RAX20?
What are the Wi-Fi channel number and channel width settings on your WavLink access point?
How far apart physically are the RAX20 and WavLink access point located?
- microsvc2Jun 02, 2024Tutor
Yes
Doorbell cam, wyse cameras and tempest station.
Wireless setup on rax20:
Enable AX; enable ssid & 20/40 coexistence; channel 11 and 600 mbps; tkip & aes
Channel 11. Unsure of width
About 40 feet. Rax in living room and wavlink in garage via Ethernet cable from the rax.
- KitsapJun 03, 2024Master
microsvc2 wrote:you indicated a second source of Wi-Fi from a WavLink access point. This source is in addition to the Wi-Fi from your RAX20.
Yes
First suggestion would be to disable the 20/40 coexistence. This sets your 2.4 GHz broadcast to 20 MHz channel width. Most IoT devices that connect to the 2.4 GHz band have no need for and cannot accommodate a 40 MHz wide channel.
Second suggestion would be to disable the AX transmission. There have been reports of this causing a problem. This would be temporary for testing. Until proven in your configuration, they are only reports. For the AX band, are you trying to use a 160 MHz wide channel?
Some good reference material here for Wi-Fi: https://www.wiisfi.com/.
- microsvc2Jun 04, 2024Tutor
I've disabled AX and coexistence. I'll monitor how this works. What should I look out for?
- microsvc2Jun 08, 2024Tutor
Hi. It worked for four days then it failed, just now.
- KitsapJun 08, 2024Master
microsvc2 wrote:Hi. It worked for four days then it failed, just now.
There may be other events causing the loss of connection. Reboot the router and keep track. An improvement none the less.
It would not hurt to do a full sequential restart of your network. Power down the modem and the router. Power up the modem and let it fully boot and show connection to the internet. Next power up your router and do the same.
Thanks for your suggestion. I do that exact thing when this happens.
- microsvc2Jun 18, 2024Tutor
I changed the channel of the wavlink to 1 (from 6) and I haven't had any issues since then. The rax20 is still on channel 11.
- KitsapJun 18, 2024Master
Thanks for the update. Time will tell for sure!
