MikeyGee1's avatar
MikeyGee1
Initiate
Jun 23, 2024
RAX20 Ethernet cable connected devices do not connect to internet
Hello, Searched and searched to no avail for a fix. Maybe one could be obtained here. The problem with an RAX20 router is that devices when connected with Ethernet cable do not connect to internet. ...
  • MikeyGee1's avatar
    MikeyGee1
    Jul 01, 2024
    First, restart the network.
    Check.
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Check
    Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
    Check…?
    Firmware of router
    V1.0.16.132_2.0.92
    Modem
    Netgear cm500
    These devices have been working together for about a year and a half. The router ports just up and quit about two months ago.
    When you mentioned firmware I researched and came across that the firmware mentioned above isn’t for this router.
    The most recent release for the RAX20 is:
    V1.0.11.112_2.0.77
    I also came across other articles that said the firmware V1.0.16.132_2.0.92 messed with port forwards, dhcp, static ip. Not all on the RAX20, but various models of router.
    So I uploaded the V1.0.11.112_2.0.77 firmware into the router, rebooted and tested that the devices now receive internet through hardline connection.
    Turned off automatic updates.
    All done, for now.
    Thanks!
