MarcNH
Aug 20, 2021Tutor
RAX20: Firmware Upgrade Failure, 1.0.3.96_2.1.46.1 GUI Language File Invalid
Just attempt a FW upgrade using the Router Update function within the RAX20. Upgrade fails indicating that the GUI Language File is invalid. Is anyone having the same issue?
- Aug 20, 2021
Glad its working! If you mark the solution as solved, it might help the next person with that issue
Aug 20, 2021Guru - Experienced User
Photos have to be approved by a moderator so we can't see what you posted for the errors.
Have you tried manually updating?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
https://www.netgear.com/support/product/rax20.aspx
- MarcNHAug 20, 2021Tutor
Thanks for the quick response.
I was reluctanct to try the manual update as the issue was an invalid GUI Language File.
I just tried the update manually several times.
Unfortunately, The downloaded file in the zip file comes through as a recovered file fragment.
There is not a valid .bin file in the zip file.
Any other thoughts?
- plemansAug 20, 2021Guru - Experienced User
I just tried it on mine and it'll show as a .chk file if you extracted it properly. (windows might not interpret it correctly). step 11 of the manual firmware process goes over it'll be either a .img or a .chk file.
Then follow the manual update process and use that chk file.
That appears to have worked successfully. 1.0.3.96 is now running.
Thanks, Marc
