MarcNH
Aug 20, 2021Tutor
RAX20: Firmware Upgrade Failure, 1.0.3.96_2.1.46.1 GUI Language File Invalid
Just attempt a FW upgrade using the Router Update function within the RAX20. Upgrade fails indicating that the GUI Language File is invalid. Is anyone having the same issue?
- Aug 20, 2021
Glad its working! If you mark the solution as solved, it might help the next person with that issue
