angerywithgear's avatar
Jul 03, 2021
rax20 had set up my network as wpa3 tried to sign on with mac book it says wpa2 password required
installed netgear rax 20 router set up my network wpa3 and tied to login on wifi and got wpa2 pass required. wifi works on iphone what gives?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
