johno023
May 10, 2023Follower
Rax20 How to change/set lan IP address ???
For what specifically?
For a device?
For the router.?
Maybe telling us what you're trying to do in detail can help more than vague questions.
https://kb.netgear.com/24088/How-do-I-change-the-LAN-TCP-IP-settings-on-my-Nighthawk-router
As plemans says, tells us what you are trying to achieve. Changing the LAN address is rarely necessary.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
