tripletaco
Sep 02, 2023Aspirant
RAX20 I can no longer change transmit power level
I can no longer change transmit power level on RAX20. I don't want to transmit on higher levels. I want 25%. Update in firmware must have changed this. I bought the router because I wanted to low...
michaelkenward
Sep 03, 2023Guru - Experienced User
Was this ever possible for that router?
If so, find the firmware that supported this and install that.
You then run various other risks – on security for example – but at least they won't fry your brain.
tripletaco
Sep 11, 2023Aspirant
How do I find the last update that still allowed power level management? Downloading and trying each of the latter firmware versions until I find the most recent that doesn't break the power level management would be extensively time-consuming. Maybe someone on the Netgear team knows the answer.
Paul
