tripletaco
Sep 02, 2023Aspirant
RAX20 I can no longer change transmit power level
I can no longer change transmit power level on RAX20. I don't want to transmit on higher levels. I want 25%. Update in firmware must have changed this. I bought the router because I wanted to low...
Kitsap
Sep 03, 2023Master
Any time you feel a firmware update has caused problems, the first course of action is to perform a firmware default reset and reconfigure from scratch. Do not import a previously saved configuration file. That action will often reinstate whatever issue you are trying to correct.
Have you performed a firmware default reset on your router since the firmware was updated?
tripletaco
Sep 11, 2023Aspirant
Kitsap,
I used to live in Kitsap County. Bremerton to be precise. I bet you are familiar with the place. Cool name!
Paul
- KitsapSep 11, 2023Master
