tripletaco
Sep 02, 2023Aspirant
RAX20 I can no longer change transmit power level
I can no longer change transmit power level on RAX20. I don't want to transmit on higher levels. I want 25%. Update in firmware must have changed this. I bought the router because I wanted to low...
Jan 06, 2025Guru - Experienced User
NG seems to not support power level adjustments on there routers anymore. If NG hasn't change this by now then mostly likely NG won't.
