R-Kasten
Mar 11, 2025Aspirant
RAX20 LAN ports are capped at 100mbs
Hello, my router (info pasted below) does not reliably give me full speed on the LAN ports specifically. I have 900+mb/s to the modem, and if I plug the ethernet cable (cat6) directly into the modem...
- Mar 11, 2025
Be sure the ethernet drivers are up to date as well.
The RAX only supports up to 1Gb connection rates so you might set a manual connection rate on the adapter for 1Gb only.Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 11, 2025Guru - Experienced User
What does the speed indicate on the routers web page under Advanced tab/Show Stats button.
Look at the connection rate for the LAN ports that have connected devices here.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
R-Kasten
The LAN port shows a speed of 100M
I am using a CAT6 cable, and when using that same cable directly from the modem I get 500mb/s. I have fiber internet from Surf and the modem is a :
UFiber loco m/n UF-LOCO. Thanks for the quick reply.
