R-Kasten
Mar 11, 2025Aspirant
RAX20 LAN ports are capped at 100mbs
Hello, my router (info pasted below) does not reliably give me full speed on the LAN ports specifically. I have 900+mb/s to the modem, and if I plug the ethernet cable (cat6) directly into the modem...
- Mar 11, 2025
Be sure the ethernet drivers are up to date as well.
The RAX only supports up to 1Gb connection rates so you might set a manual connection rate on the adapter for 1Gb only.Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
R-Kasten
I rebooted the modem and the router for about the 5th time and now I'm getting full speed. LAN2 is showing 1000M/FULL now, both desktops are using Realtek Gaming GBe 2.5 chipsets. I'm all set for now, sorry to waste you time.
Mar 11, 2025Guru - Experienced User
Enjoy. 📡
