skyking22141's avatar
skyking22141
RAX20 login timed out
I've tried changing the password several times, but those passwords do not work.  The only way I can currently access my router is via routerlogin.net, but this log in does not give me the ability to...
  • skyking22141's avatar
    skyking22141
    Aug 07, 2023
    I did some more playing around, and I now believe that because the RAX20 is an older model of router, that Netgear Genie will no longer work as it was intended.  I did login using "routerlogin.net" and have been able to get the password changed to one the router now recognized.  I was able to get everything changed that I needed to, so I am happy about that.  Thanks for all your assistance with this problem.  You can close this ticket now.
    Paul
