Tom-J
Sep 23, 2024Follower
Rax20 pauses devices on its own both Wi-Fi and direct connection
My RAX20 which I have had for 3 years just started pausing all devices on its own. I have rebooted the router several times and within a few minutes it does it again/ I have found that the Nighthawk app turns on parental control as well after I have turned it off.
1 Reply
Try a factory reset and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Do this without running any Nighthawk mobile app.After setting up the router from scratch, make a backup to file:
Then test the router out with out running the Nighthawk app.
What FW version is loaded on the router?
