fredlamsf
Aug 29, 2020Aspirant
RAX20 readyshare - intermittent speed dropped
Hi, I have purchased RAX20 and using the Readyshare with my external HDD 1. Macshare (Readshare) symption description when using Macbook Pro over 5GHz Wi-Fi When I am playing MP4 file from the ...
Christian_R
Sep 04, 2020NETGEAR Employee Retired
Hi Fred,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
- fredlamsfSep 08, 2020Aspirant
Hi,
Thanks.
Even the support has contacted, there is still no solution.
The support has told me to update to the latest firmware but my router has the said version already.
Besides, I have tested using LAN cable to test. The symptom is still there.
It seems that is the problem of readyshare.
Thanks and regards,
Fred
- Christian_RSep 15, 2020NETGEAR Employee Retired
Hi Fred,
May you send me a private message with your email address and case number(s) for us to check further.
Thanks,
Christian
- fredlamsfSep 15, 2020AspirantHi,
Your CS has told me to downgrade to previous firmware and then reset as new.
Here are the steps I have done then.
1. I have downgraded the firmware to 1.0.1.58_2.0.31. Unfortunately, after I reset the router as new, it will auto upgrade back to the latest firmware 1.0.1.64. Hope that your side aware this is embarrassing.
2. Then, I just tried to downgrade the firmware to 1.0.1.58_2.0.31, but the intermittent drop of speed is still there.
Fred
