SK2010
Oct 25, 2020Follower
RAX20 router 2.4 Ghz issues
I would like to get a solution to my problem. My router shows two wifis one is 2.4 Ghz one and the other is 5Ghz. The 5Ghz one works fine, I can connect to it with no problems. Unfortunetly that is no...
Christian_R
Oct 29, 2020NETGEAR Employee Retired
Hello SK2010,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
