rgr
Oct 27, 2021Tutor
RAX20 router loses IPV6 connectivity several times daily
Using Xfinity Modem: Netgear CM1000 Router Netgear RAX20 (which doesn't appear in the drop-down above) My RAX20 router is connected to Xfinity and loses IPV6 connectivity several times a day. I...
Oct 28, 2021Guru - Experienced User
Best way to let them know is to contact NG support and confirm with them the problem. If others are having problems as well, it's a good bet NG does as well.
Try the revert while you wait for the fix.
rgr
Nov 03, 2021Tutor
Reverted and can now keep IPV6 active for a couple days (as was the cas before. I have the router on a plu with a timer, so the router rests every other day. Obviously this won't work for the new firmware, as it loses IPV6 several times daily.
This is a crappy solution and I think it's time to find a router that doesn't have this problem.
- FURRYe38Nov 03, 2021Guru - Experienced User
đ
