rgr
Oct 27, 2021Tutor
RAX20 router loses IPV6 connectivity several times daily
Using Xfinity Modem: Netgear CM1000 Router Netgear RAX20 (which doesn't appear in the drop-down above) My RAX20 router is connected to Xfinity and loses IPV6 connectivity several times a day. I...
rgr
Nov 04, 2021Tutor
Reverted and can now keep IPV6 active for a couple days (as was the cas before. I have the router on a plu with a timer, so the router rests every other day. Obviously this won't work for the new firmware, as it loses IPV6 several times daily.
This is a crappy solution and I think it's time to find a router that doesn't have this problem.
Nov 04, 2021Guru - Experienced User
