Retired_Member's avatar
Retired_Member
Apr 27, 2022
RAX20 VPN Client
Good Morning,
i'm missing 2 things, one is to be able to set the router as open vpn client and be able to specify the devices that will use it, can this be implemented on the next update? That's a must for such a powerful router.
The second is, i would like to be able to route my entire traffic to an internal server that i have but it seems that the ip routing only works to ip ranges or so, i wish to have an ip table configuration that enables to to route for example all traffic from 192.168.2.1 to 192.168.2.10 or so.
Thanks in advance.
No Replies
