samata
May 12, 2023Follower
RAX20 won't turn on
I have had my RAX20 router for about 2 years now. We had some storms lately, but the router itself is plugged into a surge protected outlet. Ever since, the router will not turn on and lights do not ...
May 13, 2023Guru - Experienced User
The "check the power supply" suggestion is very valid. usually if something is corrupt in the router, you at least get lights. Maybe something in the storm fried the power supply. Or tripped the power strips breaker. Does everything else on the power strip work?
- michaelkenwardMay 13, 2023Guru - Experienced User
Having a surge protector in front of a device is useless when thunder and lightning are out and about.
Check the marketing for these devices and they will warn you that they are not up to the job.
Do Surge Protectors Protect Against Lightning?
Does A Surge Protector or a UPS Protect Against Lightning?
Lightning can deliver too big a spike that is much faster than the protection can handle.
If you have a spare adapter/transformer with the same output as the suspect one try that. The good news is that the adapter may have blown up before the spike hit the router.
