Andreas-Jackson
Mar 04, 2022Aspirant
RAX20
Help required in the control panel of my rax20 wifi router it keeps stating reboot even though i have and updated the software once i have solved this issue i have purchased another rax20 and wish to...
- Mar 04, 2022
Are you talking about using the 2nd router in access point mode?
Or are you still having issues? If its still issues, a better description of the problem would be advised.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Mar 04, 2022Guru - Experienced User
