jtma67
Mar 20, 2023Aspirant
RAX200 - Allowed Device Table Corrupted?
When cleaning up my router, I found there appears to be corruption in the 'Allowed Devices Connected to the Network" Table. One entry seems to be missing the check box that would allow changes to be...
- Apr 19, 2023
Since you factory reset and setup from scratch, now save off a new backup config to file for safe keeping. I would use MS Edge or Firefox for this.
Please mark your thread as solved so others will know.
Enjoy.
Mar 20, 2023Guru - Experienced User
What browser are you using?
Be sure to clear out all browser caches before entering the routers web page.
Try a different browser?
Try a different PC to see if problem follows...
Your behind on FW:
I'd do a factory reset and setup from scratch before updating FW.
- jtma67Apr 19, 2023Aspirant
Sorry for the late response.... I did try different browsers and the problem was unchanged. My resolution was to factory default the router and reenter allowed users. Thanks for your input none the less. John
