jtma67's avatar
jtma67
RAX200 - Allowed Device Table Corrupted?
When cleaning up my router, I found there appears to be corruption in the 'Allowed Devices Connected to the Network" Table.  One entry seems to be missing the check box that would allow changes to be...
  • FURRYe38's avatar
    Since you factory reset and setup from scratch, now save off a new backup config to file for safe keeping. I would use MS Edge or Firefox for this.
    Please mark your thread as solved so others will know.
    Enjoy.
