RichardBenson
Jul 12, 2021Aspirant
RAX200 - Ethernet Port - Red light
Hi, I recently purchased a new router, the RAX200, and I'm extremely happy with its performance. However, as of last night, the ethernet port keep on showing a red light instead of a steady w...
Jul 12, 2021Guru - Experienced User
Which ethernet port?
1-5?
Wan port?
If its the 1-5 port, it indicates a 10/100mbps connection and not gigabit.
- RichardBensonJul 12, 2021Aspirant
Hi Plemans,
Thank you for your response.
So the ETHERNET port I was referring to is the YELLOW RJ45 port that the router uses to connect to the ISP modem.
Thanks for all your help :)
- plemansJul 12, 2021Guru - Experienced User
What ISP modem is it? (model)
Have you checked the cable? I've seen sketchy cables cause issues.
Make sure its a cat 5e or better cable and decent quality
Hi Plemans,
The Spectrum Modem is a DOCSIS 3.1 cable modem - 3.1 E31N2V1 Hitron.
Also, ethernet cable looks good, decent quality - Cat 7... Been using it for a few months, no problem.
