Unbreak_Able
Oct 12, 2022Aspirant
RAX200 - Extender IP addresses on devices page
Hi all, I have a RAX200 that I got recently but need wifi to the driveway and garage. So using old asus router as range extender (repeater). The Asus as repeater mode will only show connected devices...
- Oct 12, 2022Something I should probably have mentioned ; I spoke to NG support earlier and they confirmed that the router will only show one IP per attached device and it will only show devices connected directly to the router (will not show devices connected to the repeater/extender).
Unbreak_Able
I've run the asus as repeater for the old Vodafone isp router and it was passing them through to that fine. So I don't think it is the Asus router.
Oct 12, 2022Guru - Experienced User
Try a NG branded extender/repeater to check that.
- Unbreak_AbleOct 12, 2022AspirantI don't have an NG branded extender/ router to use as extender/router. Had one years ago but a mate asked to buy it off me so that is gone.
Don't think the brand of extender/repeater router should matter though.
Appreciate the suggestion however.
