Unbreak_Able
Oct 12, 2022Aspirant
RAX200 - Extender IP addresses on devices page
Hi all, I have a RAX200 that I got recently but need wifi to the driveway and garage. So using old asus router as range extender (repeater). The Asus as repeater mode will only show connected devices...
- Oct 12, 2022Something I should probably have mentioned ; I spoke to NG support earlier and they confirmed that the router will only show one IP per attached device and it will only show devices connected directly to the router (will not show devices connected to the repeater/extender).
Oct 12, 2022Guru - Experienced User
I could be the asus in extender mode is using its own IP address range to assign to devices.
have you checked that?
Unbreak_Able
The Asus doesn't have any IP address range in repeater mode. All that gets disabled when you put it in repeater mode.
Besides, the Asus addresses have always been traditional (192.168.1.*) whereas the RAX200 changed them to bespoke so as not to clash with the Vodafone router (which I have to keep as ISP gateway for FTTP).
