Sbokh
Jan 03, 2020Aspirant
RAX200 - Not broadcasting SSIDs
Hi,
I am trying to setup RAX200 and whatever I do can't seem to find the SSIDs on any of my devices. Looks like theses are not even being broadcast. Checked all online solutions, but no luck. Lan is working just fine.
- Tried enabling/ disabling SSID Broadcast.
- turned AX off.
- reset router to factory default and went through setup
- Changed SSID Names
- Enable/ disable Router Radio in Wireless settings and with the manual button
- Wireless Settings (5 GHz) in Advance Home shows Channel as "�����aL���O��". Did try and change channels randomly but in vain.
Please help/ advise.
Thank you.
SB.
New device?
Return to seller.
- SbokhAspirant
I downgraded the firmware to 1.0.0.30. The "Home" now shows Wireless status as "OFF". Can't turn it on anywhere.
New device?
Return to seller.
- SbokhAspirant
Ended up returning. Thank you.
