Wifi6SoGood
Nov 27, 2021Aspirant
RAX200 - PS5 Won't Connect to Internet
Hey Netgear Community, I just joined the Nighthawk family today. I spent the better part of tonight migrating ~40 wifi devices at my home to the new Nighthawk Wifi (I run it in AP mode). Every devic...
Nov 28, 2021Guru - Experienced User
Can the PS5 ethernet connect to the RAX in AP mode and get internet? Do same with console connected to the firewall device.
IF your other devices are connecting to the RAX in AP mode and the PS5 can't, this would probably be a PS5 issue. There are some known issues with newer game consoles. 1, xbox causing bad networking issues when connected. I believe PS has some wifi issues on the radios.
Again, the RAX in AP node is just passing thru traffic and not doing ANY routing. Your host router or firewall is doing that and could be causing problems.
Rhudman
Nov 28, 2021Aspirant
I'm having the same problem after installing my new CAX30 model. Spent 7 hours last night on the phone with Netgear trying to set mine up. Finally got everything connected.....except the PS5. It is hard wired and shows on the network, but the router isn't allowing it to get a connection.
- FURRYe38Nov 28, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the CAX Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
