Sualdam
Apr 10, 2023Aspirant
RAX200 - Restricting Port Access to external IP Range
Apologies for a long preamble on this. Problem: I have a streaming camera which works. I can see it on my home network all the time. I use a streaming service based in the USA, and I can embed the...
Apr 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is uPnP disabled while you have PF configurations enabled?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Sualdam
I have the latest firmware - V1.0.10.140_1.0.79.
The Modem is a Virgin Media Superhub 4 (set to modem mode). It isn't a problem with that.
There are no cabling issues. Everything works, and there are no hardware issues.
The camera is permanently visible on my home network. The problem is purely to do with ports 'closing'. As in ports open, camera streams, but ports closed, camera doesn't.
The only issue is those ports repeatedly - between 2-10 times a day - appearing closed from the outside, whilst appearing open from inside. They close and re-open themselves (from the outside) when Armor is enabled, but remain open continuously when Armor is disabled. They opened immediately during a closed period as soon as I disabled Armor. So it has to be concluded that Armor is making them appear closed (even when they are not, according to netstat).
I have been advised to restrict the port access (for port 554) to a specific IP range given me by my streaming host while Armor is disabled - and to see if doing that prevents Armor doing whatever it is doing when a port is scanned maliciously, or to at least afford some protection.
So my question is: how do I restrict access to a port to that range of incoming IP addresses (on the RAX200)?
- FURRYe38Apr 10, 2023Guru - Experienced User
Seems like a issue with Armor if the ports work properly with Armor disabled.
- michaelkenwardApr 10, 2023Guru - Experienced User
Sualdam wrote:
The Modem is a Virgin Media Superhub 4 (set to modem mode). It isn't a problem with that.Famous last words. ISP modem/routers are notoriously cranky.
- SualdamApr 10, 2023Aspirant
My question is how do I restrict access to a port to a defined range of external IP addresses on the RAX200?
