Synomenon
Aug 10, 2020Star
RAX200 - Updated to firmware version 1.0.2.98_1.0.54 -> NTP settings not saving now.
Updated my RAX200 to firmware version 1.0.2.98_1.0.54. After update, I rebooted the router again.
Now when I go to:
Advanced -> Administration -> NTP Settings
when I change "Time Zone" my time zone (GMT -8:00 Pacific Time) and check the box to "Automatically adjust for daylight savings time"
THEN hit the Apply button, the page will come back up after with Time Zone set back to (GMT - 12:00 International Date Line West) and "Automatically adjust for daylight savings time" unchecked.
Anyone else with the RAX200 experiencing this?
I have the same issue with the Time Zone defaulting to International Date Line West. The correct time zone should be Pacific US. The date is also showing as August 9, when the correct date is August 14. Resetting the router has not fixed the problem. The firmware is V1.0.2.98_1.0.54
- russwebInitiate
I have this problem also.
And it is causing a problem with me using online services. For some streaming providers, it thinks Im in a different time zone.
For one other product I PAY for online, it will not let me access the site because it thinks I am out of the country.
This is a big problem!
This only started happening when I upgraded my firmware.
Even the latest version today (11/5) does not fix this.Help!
- brianwcaAspirant
I have the exact same problem with saving time zone and NTP settings on my RAX200, using firmware V1.0.3.102_1.0.56. It also seems to be messing up my schedule to block certain devices (probably because the router doesn't have the timezone correct). However, I'm also on Pacific time (-8) and getting the Int'l West (-12), so it should only be 4 hours off, but my 21:30 shutoff time seems to kick in at 13:30 instead, so it operates as if it's off by 8 hours. I don't know what's going on, but this is a seriously expensive router to have such basic problems. Really disappointing.
- dejannenovAspirant
The issue is presetn with the latest firmware - the timezone is NTO correct and the Scheduling feature for disabling access to ports is not working. This needs to be fixed.
Firmware: V1.0.3.106_1.0.58
