DR_H
Feb 27, 2020Follower
RAX200 - weird log entries
Hi,
Hoping someone can help with this as it's causing me some worry.
Checking through the logs, I'm seeing a lot of ACK attacks from Apple, Google and Amazon. But the worrying bit is that I'm seeing a lot of blank entries in the log in the middle of the night showing just:
Thursday, Jan 01,1970 00:00:00
Probably about 30 or so in between proper entries about new connections and DoS / ACK attacks.
Is this just a bug or has someone managed to infiltrate my router and then mostly clean up after themselves?
Thanks.
DR_H
- Christian_RNETGEAR Employee Retired
Hello DR_H,
This is usually a false report. Furthermore, I would recommend contacting our Support Team for additional info on the logs.
https://www.netgear.com/support/default.aspx
Christian
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
