SpecialK214
Apr 14, 2020Tutor
RAX200 - WPS light continues blinking. Already tried rebooting.
I recently installed Netgear CM1150V Modem, RAX200 Router and EX7700 Extender. Everything is set up and working. When connecting my Extender, I used the WPS feature. Now the WPS light on the Route...
japierce
May 18, 2020Guide
ditto, my RAX-200 when connected to my x6s extender is contantly blinking.
Are we leaving our network vulnerable?
Please help netgear, where are you???
BLUE-DRAGON
May 18, 2020Guide
were the **bleep** is new firmware
Please release a new firmware right away. When you push the WPS, the light constantly blinks and doesn't turn off. It leaves my network open to attack. Please fix this right away.
- Christian_RMay 21, 2020NETGEAR Employee Retired
Hello Nighthawk Community,
Our engineering team is aware of an issue with the WPS LED light blinking on the RAX200. They are working on a fix but we currently do not have an ETA on the next firmware release.
Christian
- JPaquetteMay 21, 2020Star
Thank you!look forward to the new firmware release.
jim
- SpecialK214May 30, 2020Tutor
Hi Chrisian,
Any update on the Firmware Update to stop the WPS light from constantly blinking?
Just to update, I turned off Smart Connect and have re-setup my router several times now, no change. The WPS light continues to blink. Please provide an update on when the Firmware Update will be made available to fix this issue.
- Raiden85May 31, 2020Star
Hopefully this issue will be fixed soon. Bought the RAX200 this week and had to use WPS to setup a printer, on the latest firmware 1.0.2.88 it will blink forever once pressed.
I did fix it temporily by downgrading to 1.0.1.12, this thankfully kept my settings and stopped the blinking. I then upgraded back to 1.0.2.88 and the blinking has stopped while still retaining all my settings. Can't press this again otherwise it will cause it to blink again. Seems this bug only occured since the 1.0.2.88 firmware.
Apart from that small issue I'm very happy with this router coming from the RX8000.
