SpecialK214
Apr 14, 2020Tutor
RAX200 - WPS light continues blinking. Already tried rebooting.
I recently installed Netgear CM1150V Modem, RAX200 Router and EX7700 Extender. Everything is set up and working. When connecting my Extender, I used the WPS feature. Now the WPS light on the Route...
SpecialK214
May 30, 2020Tutor
Hi Chrisian,
Any update on the Firmware Update to stop the WPS light from constantly blinking?
Just to update, I turned off Smart Connect and have re-setup my router several times now, no change. The WPS light continues to blink. Please provide an update on when the Firmware Update will be made available to fix this issue.
Raiden85
May 31, 2020Guide
Hopefully this issue will be fixed soon. Bought the RAX200 this week and had to use WPS to setup a printer, on the latest firmware 1.0.2.88 it will blink forever once pressed.
I did fix it temporily by downgrading to 1.0.1.12, this thankfully kept my settings and stopped the blinking. I then upgraded back to 1.0.2.88 and the blinking has stopped while still retaining all my settings. Can't press this again otherwise it will cause it to blink again. Seems this bug only occured since the 1.0.2.88 firmware.
Apart from that small issue I'm very happy with this router coming from the RX8000.
