SpecialK214
Apr 14, 2020Tutor
RAX200 - WPS light continues blinking. Already tried rebooting.
I recently installed Netgear CM1150V Modem, RAX200 Router and EX7700 Extender. Everything is set up and working. When connecting my Extender, I used the WPS feature. Now the WPS light on the Route...
cphymel
Jul 10, 2020Aspirant
Please release a new firmware right away! When you push the WPS, the light constantly blinks and doesn't turn off. Does the leave my network open to attack or unauthorized devices to connect? Please fix this right away. Is Netgear even working on this issue? What is a ETA for new firware to get the fix? Just purchased, but may return this unit and go back to Belkin! For the top of the line unit and the very expensive cost of this unit, this model should be trouble free! I have tried most all the attemps by others, but still in the same position of the blinking light. It is incomprehensible how this issue was not found in the development and testing process.
Netgear, your reputation is on the line here!
CPH
- JPaquetteJul 10, 2020StarYep, the blinking light continues! I've been told several times by tech support that “ it’s normal and not to worry “ somehow it’s not comforting. I have owned only Netgear products for many years, this unit has been a huge disappointment! Tech support is useless! Jim
- cphymelJul 10, 2020Aspirant
Thanks for your reply.
I did come accross a setting that gives this option:
"Block all new devices from connecting"
Hopefully this will help with the security issues of unauthorized users.
This setting is located under the advanced tab/security/access control
CPH
- BLUE-DRAGONJul 10, 2020Guide
i find a fix for this
i got rid of this and got the AmpliFi ALIEN Router so much better and way faster then the rax200
