SpecialK214
Apr 14, 2020Tutor
RAX200 - WPS light continues blinking. Already tried rebooting.
I recently installed Netgear CM1150V Modem, RAX200 Router and EX7700 Extender. Everything is set up and working. When connecting my Extender, I used the WPS feature. Now the WPS light on the Route...
cphymel
Jul 10, 2020Aspirant
Thanks for your reply.
I did come accross a setting that gives this option:
"Block all new devices from connecting"
Hopefully this will help with the security issues of unauthorized users.
This setting is located under the advanced tab/security/access control
CPH
BLUE-DRAGON
Jul 10, 2020Guide
i find a fix for this
i got rid of this and got the AmpliFi ALIEN Router so much better and way faster then the rax200
- kryptoknightJul 23, 2020Tutor
I'm also getting the same problem; router is currently on firmware version V1.0.2.88_1.0.50. Looks like there's a new beta version for download - V1.0.2.92_1.0.50_beta - on the Netgear support site. The release notes for it sucks - just says "security fix" and no other details. Hesitant to push this to my router since it's beta and I have no idea what's in it. I'm actually disappointed in the new products from NetGear. I also purchased the EAX80 and having disconnect issues with EAX80 extender. But I digress. These issues are serious which cause core functionalities and security risks. Support is par at best. These problems shouldn't even be happening if these products/firmwares are thoroughly tested before release (serious QA control). And when these problems are reported, they should be fixed immediately, not wait for months on end without any updates. I used to be a fan of Netgear and a huge advocate for their products. I've already invested in these products and can't return them because my return window has passed. Now all I can do is just wait and wait and wait for firmware updates in the hopes that these updates will fix these core issues. If not, I might just consider dumping them for a loss and getting a new router/extender or mesh system from another vendor.
