Eddie1G
Jul 26, 2023Follower
RAX200 & CM2000
I Have 2000 Mbps (2 GIG) Internet Service Plan, and also have a CM2000 Modem and a RAX200 router. I changed to the Multi-Gig Port option on settings. So, now the Modem is connected on the Multi-Gig P...
Jul 27, 2023Guru - Experienced User
Just keep in mind the RAX200 only has the 1 multigig port. so the max output from it is only going to be 1 gig.
You'll still be able to use the 2gig speeds but only through multiple devices or potentially wifi .
