JosephBanks
Jul 30, 2022Aspirant
RAX200 & EAX80 vs Orbi Mesh System
Hi, I am planning my new home which will be a reasonably large 2 storey home, about 450sqm/5000sqft (~225sqm/2500sqft per floor) and the block of land is about 800sqm/9000sqft. The facade of ...
Jul 30, 2022Guru - Experienced User
Depending on placement and distances either the RAX/EAX system would work or the Orbi system would work for most of the internal home coverage. I have a 5k sq ft home and most of the time just 1 router and satellite is sufficient. I can run two satellites however I turn down the power to 50%.
