JosephBanks
Jul 30, 2022Aspirant
RAX200 & EAX80 vs Orbi Mesh System
Hi, I am planning my new home which will be a reasonably large 2 storey home, about 450sqm/5000sqft (~225sqm/2500sqft per floor) and the block of land is about 800sqm/9000sqft. The facade of ...
JosephBanks
Thanks for the fast response!
It sounds like I’ll have a better time with the Orbi, I’ll go with that, maybe the AXE11000?
Will I get a better result using wired back haul between the satellites and the router? Also, can I plug one of the router ports into a switch to provide the cables network?
Thanks so much!
Joseph
Thanks so much!
Joseph
Jul 31, 2022Guru - Experienced User
You can connect RBS to the RBR via ethernet:
