jlf20210720
Jul 20, 2021Initiate
RAX200 + EX7700 + EX8000
New thread started from French support, but displayed on English page. How to move it to correct site ? Bonjour, J’ai l’architecture réseau suivante : Internet <-> box ADSL <-> RAX200 <-> ...
Jul 20, 2021Guru - Experienced User
Try just changing one of the devices names. If one of the extenders is using a different ssid, potentially it keeps the other from connecting to it. I recommend the EX7700 as it has the slower backhaul than the EX8000.
Use the "smart connect" option so the ssid's are all the same for 2.4ghz/5ghz. Parenthesis will be names
go:
EX7700 (Home2)<-----------RAX200 (Home)--------->EX8000 (Home)
if that doesn't work, then just use different names for the extenders. but again, use smart connect so your not having seperate names for each band as well.
so:
EX7700 (Home2)<--------RAX200(Home)---------->EX8000 (Home3)
- jlf20210720Jul 26, 2021Initiate
Hi,
First of all, thanks for you answer.
I performed some tests, and I got a strange result :
- RAX create Home-2G + Home-5G-44 and Home-5G-100 (ch 44 & 100)
- EX7700 using Home-2G + Home-5G-100 to create a unique Home-EX7700
- EX8000 using Home-2G + Home-5G-xx to create a unique Home-EX80000
If EX8000 uses Home-5G-44 as input, the new Home-EX8000 is strange : for example, smartphone (Galaxy S20 + Galaxy S20 FE) are unable to use this wifi (said as connected without Interne). If a stop mobile data on these phones, there is really no internet (checked with google page). But computer (laptop + tower) are able to connect on Internet...
If EX8000 uses Home-5G-100 as input, everything is fine on Home-EX8000.
This 2nd configuration (EX8000 on 5G-100) is active and being tested for stability. I will try later to merge all RAX to a single SSID.
Best Regards,
JL
