jonshamieh
Nov 11, 2020Guide
RAX200 + Orbi best practice
I currently own a RAX200 for my one bedroom apartment. It's amazing. I just bought a 5 bedroom house (2300 sqft) and have CAT6 run to every room. Sonic Fiber Modem is in garage. I have 9 ethernet lines that terminate in the garage near the modem.
I am thinking to add an Orbi Mesh to the system. I just am torn -- should I use the RAX200 straight from modem and use Orbi as Access Point and satellites from there? Or should I run the Modem straight to Orbi and set up my RAX200 as an Access Point in one of the bedrooms?
modem--RAX200--Orbi (AP)--Orbi Satellites
-OR-
modem--Orbi--Orbi Satellites--RAX200 (AP)
I'd first just try it out with the RAX200. It has surprising range/capabilities.
Just centrally locate it in the home.
If it doesn't work, Then i'd go:
modem---rax200------mesh setup in AP mode
- I would but the RAX200 will be in garage as that’s where all my ethernet jacks terminate. So I’ll need a switch down there and a router before the switch. I guess I could get a cheaper wired only router, but I like the idea of having RAX200 be the main brain of whole network.
You sure can do it.
I ran it that way for a while
I had a CM1100----->rax200----->orbi rbk53 system
the orbi system was ran in AP mode. The only other thing I made sure that I did was my satellites that were connected via wired backhaul, connected directly to the rbr50 and not through the rax200 then rbr50
