jonshamieh
Nov 11, 2020Guide
RAX200 + Orbi best practice
I currently own a RAX200 for my one bedroom apartment. It's amazing. I just bought a 5 bedroom house (2300 sqft) and have CAT6 run to every room. Sonic Fiber Modem is in garage. I have 9 ethernet...
jonshamieh
Nov 11, 2020Guide
Thank you. This is exactly the type of info I was looking for. Very helpful. I am also considering the Nighthawk Mesh WiFi 6 system - I know it's not TriBand, but might be all I need for extra coverage to rest of house. Most of my devices will be hardwired via Gigabit lines anyway. Orbi might be overkill. I assume with the Nighthawk Mesh the idea is exactly the same, run the main in AP, and then chain the Satallites to it. Although there aren't enougn ports on the Nighthawk to backhaul each one via wrired. hmmm...
Nov 12, 2020Guru - Experienced User
running them with the wired backhaul is ideal since its just the dual band system. A cheap gigabit switch would fix the port issue.
- jonshamiehNov 12, 2020Guide
Got it, thank you!
plemans wrote:running them with the wired backhaul is ideal since its just the dual band system. A cheap gigabit switch would fix the port issue.
Yep I have a 5-port gigabit Netgear unmanaged switch that will be hit directly after RAX200.MODEM-RAX200-MK63 Router-GS305-MK60 Satellites
Some other three wired ports from the RAX200 will go directly to select rooms and will hit switches of their own.
Sorry, to correct my last post, the the GS305 switch will be hit after the Nighthawk Mesh router (in AP mode) - not after the RAX200.
- plemansNov 12, 2020Guru - Experienced User
should work great!
