張勝硯
Oct 23, 2022Aspirant
RAX200 1.0.10.140 Frequent disconnection
I recently updated to the latest firmware (1.0.10.140), and I often get disconnected internet for a few seconds, and it happens many times in a day, I can only go back to the firmware (1.0.5.132) to s...
Oct 25, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
