kevinluo1990
Aug 14, 2020Tutor
RAX200 1.0.2.98 firmware problems
All the problems I'm going to mention below have been exsisting since Match 2019 and need to be fixed. 1. The router "smart connect" seems like doesn't work, because it shows 2.4, 5-1 and 5-2 separ...
Christian_R
Aug 20, 2020NETGEAR Employee Retired
Hello kevinluo1990,
Thanks for the feedback. I'll have the information forwarded to our product teams for review.
Christian
kevinluo1990
Sep 03, 2020Tutor
Thank you for your replay. And I just found another bug about the guest wifi name.
For example, I set up my own wifi with name "ABC", and Guest wifi Name "DEF". And when I enable the guest wifi via Mobile App, the guest wifi name will automatically changed to "ABC- guest-2.4G" or "ABC- guest-5G" accordingly. It is works fine if I enable the guest wifi via webpage. I've tried multiple times.
