RajaDaja
Aug 03, 2020Luminary
RAX200 1.0.2.98 Firmware
Did anyone update their RAX200 to 1.0.2.98 firmware? If so, is everything working as it should? Thanks
- Aug 07, 2020I still have IPV6 issues. Reloaded firmware 1.0.2.8. This was the last update that work for IPV6. The latest updates have IPV6 issues.
PLG
Aug 04, 2020Aspirant
Has anyone had any issues with the router’s Real-Time clock since upgrading to v98
The router clock no longer updates with the result scheduling does not take place at the appropriate time.
I have completely reset the router to default parameters after the update, but the clock is set to some random time and stuck even when the NTP server is changed and/or the time zone is reset. I suspect it is something to do with NETGEAR’s automatic time zone detection algorithm. Is there any way to switch that off?
I have had issues with Attached Devices page no updating properly. Indicating devices are attached when they have been off for hours.
Retired_Member
Aug 04, 2020You're right. It's 1100 am local here on the 4th and the NTP set at Netgear shows 0930 on the 3rd. I always set the correct time zone but never paid attention to the time. more than a day off.
