RajaDaja
Aug 03, 2020Luminary
RAX200 1.0.2.98 Firmware
Did anyone update their RAX200 to 1.0.2.98 firmware? If so, is everything working as it should? Thanks
- Aug 07, 2020I still have IPV6 issues. Reloaded firmware 1.0.2.8. This was the last update that work for IPV6. The latest updates have IPV6 issues.
Kris82
Aug 10, 2020Star
I updated the firmware over the weekend. Yesterday I noticed that the date on the router was wrong. I had the NTP server set to Netgear's default. I switched to another one, but it made no difference. I rebooted the router and saw that the date got corrected. But some time later I saw the time was frozen to the time I rebooted the router. This morning when I logged into the router again, I saw the date was still set to yesterday and the time was still set to the time of the router reboot. All entries in the log were set to the same date/time. I strongly suspect the updated firmware caused the problem.
JohnDiV
Aug 11, 2020Star
How do you Check and set the time? Where can I find it on the menus?
Thanks
Thanks
- Kris82Aug 11, 2020Star
Log into the administrator interface, then Advanced => Administration => NTP Settings.
You can't set the time directly, but you can specify the time zone and NTP server, as well as seeing what date/time the router thinks it is.
