RajaDaja
Aug 04, 2020Luminary
RAX200 1.0.2.98 Firmware
Did anyone update their RAX200 to 1.0.2.98 firmware? If so, is everything working as it should? Thanks
- Aug 07, 2020I still have IPV6 issues. Reloaded firmware 1.0.2.8. This was the last update that work for IPV6. The latest updates have IPV6 issues.
PLG
Oct 04, 2020Aspirant
Loaded V1.0.2.102_1.0.56. NTP time now working but but stuck at Date Line West time. Cannot set to local time zone or for Daylight Saving. Reverted back to V88. Did a hard reset and reloaded V102. Still unable to set to local time zone or for daylight Saving. Reload V88 config file on top of V102. Time now set to Local Time zone but GUI still indicates that router is set to Date Line West and unable to change. Left router in that state. Probably now going over to ASUS. At least their update releases appear to clear bugs rather than create new ones!
JohnDiV
Oct 04, 2020Star
HI, I went to the Asus GT-AX 11000 and it works great no problems what so ever. I us the RAX200 piece of **bleep** as an Access Point now. An expensive AP what it does work well as the AP. I gave up on Netgear 2 firmware updates ago.
Good Luck
- PLGOct 05, 2020Aspirant
Hi
Many thanks for the advice. I'll look out for the router.
Cheers
